RCU Forums
-   3D Flying! (https://www.rcuniverse.com/forum/3d-flying-82/)
-   -   ESM katana 40 (https://www.rcuniverse.com/forum/3d-flying-82/3616003-esm-katana-40-a.html)
richohealey 12-04-2005 03:37 AM
ESM katana 40
hey guys. need a ew 3d plane. the ad says less than 4 lbs. looks good. what do you guys think with a 46FX?
richo
skukreja 12-04-2005 07:42 PM
RE: ESM katana 40
where can I find the website...
rhk 12-07-2005 11:50 PM
RE: ESM katana 40
Try www.singahobby.com. the katana 50 also looks like another great option.
R
mathinstrument 12-08-2005 01:31 AM
RE: ESM katana 40
The ESM katana which my friend had was great. He mounted a saito 100 / 20% on it and it hovered at less than midstick. Excellent pullout power!
Rowdy1 12-08-2005 11:53 PM
RE: ESM katana 40
Be careful with this one. I just purchased it, great kit but it weighs 3.96lbs as the add says but that's with no engine or radio!
Rowdy
richohealey 12-11-2005 06:28 AM
RE: ESM katana 40
you serious about the 4 lbs without radio or engine???? waqs gunna stick a 46SF in it, but may go back to the ultra-RC katana 50 if thias is true. can anyone confirm?
Rowdy1 12-11-2005 07:39 AM
RE: ESM katana 40
I have the kit right here,Freestyle Katana 40 by ESM. the manual says flying weight of 3.96LBS. However I weighed the kit as is and it weighs exactly that with no engine or gear. Now if you look at the lid of the box it states a flying weight of 2.44 Kgs. That's the facts, I was disappointed however with a saito 82 up front it should still perform. I have not built it yet but as I said the bare kit weighs a tad under 4lbs.
Rowdy.
richohealey 12-19-2005 01:24 AM
RE: ESM katana 40
BLOODY hell. scrap that idea then. new ideas?
Bxtreme aviator 08-29-2007 08:29 AM
RE: ESM katana 40
hi guys
im new in da flying bisniss am 13 years old and hav only flown for 2 years. i dont hav dat much experience im still flying my 2 trainers and am looking at da katana 40.my instructer owns da local hobby shop and has 1 der. I gave da deposit alredy so im lockin forward to flying da thing. Is it realy dat heavy?da guys here say dat it will run nicley with a OS 46 2 stroke i have 1 hear so it wil save me lots.and are there problems with da CG (center of gravity) with da plane i know dat da twists hav tail heavy problems.
thanks jp
every landing you walk away from is a good landing!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!:D
Spacey 08-30-2007 02:20 AM
RE: ESM katana 40
ORIGINAL: Bxtreme aviator
hi guys
thanks jp
I'm sure if you want to fly normal aerobatics (Loops, avalanches, cubans and the lot) this brick will be good fun even with a .46 on it. You decide. You want to 3D this sucker? Forget it, I doubt the plane will even be capable and if it is it'll probably do so with only sweat and tears. If you're gonna use it for an advanced flying brick transition from your trainer you'll have a ball with it...I think! :)
JoeyCoates 10-09-2007 10:40 PM
RE: ESM katana 40
Does this look like a H9 Funtana 40/X50 to anyone else? For any of you who have one am I wrong or is it a pretty close copy? does it have that same blunt LE? If it has a sharper LE (like a lot of people are doing on their Funtana's) then it is probably a good airplane. I just lost my X50 to a midair two weeks ago and I had done the LE mod on it. It was a great flying plane once the LE was fixed though, I learned A LOT with that airplane and I have been flying for 20+ years!
Bxtreme aviator 12-06-2007 03:47 AM
RE: ESM katana 40
Hi
My Instructer has a Funtana 50 and to comparismant to myn its quite the same exept the elevator the KATANAS elevator has an airfoil the FUNTUNAS has an normal balsa shape. The Wing is also a bit different it.It is thicker and longer but the flight characteristics are the same. The fuselage is almost exactly the same.
cheers jp
Dav0012 12-06-2007 05:05 AM
RE: ESM katana 40
i have one of these planes myself, and i fly at the same field that richo does but as you can see this post is 2 years old..., with a 46 size 2 stroke you need 100-200 grams of weight in the nose to get close to balancing, i have a millenium 61 in the nose and it is only just balanced. although it has the lightest wingloading out of all the planes ive had. In wind, i just glide it around on 2 clicks above idle, untill it starts to stall which is basically just a mush of the control surfaces. but this thing just floats around
