3D + perry pump
Hi!
I have a plane that has the fuel-tank right behind the engine ... I haven't had any flameouts, but I think the engine (a Saito .91) is not receiving enough fuel when accelerating to full after I've hovered for about 3 minutes ... Will installing a Perry Pump help at all or should I keep things simple and not mess with pumps ? |
that sounds funny!
what are the symptoms to make you say that its not getting enough fuel after a hover? Also is this something that richen up the high end could fix?
Which One
There is a VP-30 and the oscillating pump. Not sure if you can use the VP on a 4 stroke?
3D + perry pump
the 20 is 2 stroke
the 30 is 4 stroke i ran the 30 on my satio 180 great product. i will be running the 20 on my 2-os-160 |
3D + perry pump
I havent had the great success with the perry line that others have had. I started using Cline and have not had a problem. It is a "diffrent" set up from the others. I am now running Cline on a Saito 1.8 a OS 1.6 and a Moki 2.1 and love 'em. I would recomend it.
| All times are GMT -8. The time now is 02:12 AM. |
