RCU Forums
-   3D Flying! (https://www.rcuniverse.com/forum/3d-flying-82/)
-   -   Dave Patrick Ultimate (https://www.rcuniverse.com/forum/3d-flying-82/363460-dave-patrick-ultimate.html)
AV8TOR 11-13-2002 12:23 PM
I do not have the original manual and I acquired a used Ultimate, would someone please share the recommended control throws (both Low and High) and CG range. This is for the 60.5” wing model.? Thanks
14th_Reaper 11-13-2002 01:39 PM
High Rate UP Down
Aileron 3/4" 3/4"
Elevator 2-1/2" 2-1/2"
Rudder 3" 3"
Low Rate UP Down
Aileron 1/2" 1/2"
Elevator 1-1/2" 1-1/2"
Rudder 2" 2"
3-D Throws
Aileron +/- 1"
Elevator +/- 4-1/2"
Rudder +/- 5"
AV8TOR 11-13-2002 03:16 PM
Originally posted by 14th_Reaper
High Rate UP Down
Aileron 3/4" 3/4"
Rudder 3" 3"
Low Rate UP Down
Aileron 1/2" 1/2"
Rudder 2" 2"
3-D Throws
Aileron +/- 1"
Elevator +/- 4-1/2"
Rudder +/- 5"
Thanks Reaper. On the elevator where is that measured from, the back edge at the widest point or the counter balance farthest point?
14th_Reaper 11-13-2002 06:39 PM
Well, I am not sure, and Unfortunately the manual is at home and I am at work.... will get back with you later...
skip ahead a few hours in time........
"All measurements are from the center of the control at the widest point!"
straight from the mans mouth! I have a manual but no plane.... send me a self addressed stamped envelope and you can have my manual...
