RCU Forums
-   3D Flying! (https://www.rcuniverse.com/forum/3d-flying-82/)
-   -   JR servos for pattern (https://www.rcuniverse.com/forum/3d-flying-82/3773589-jr-servos-pattern.html)
apereira 01-14-2006 12:11 PM
Hello Andrew, can you help me in choosing the servos for my next pattern plane?, I usually use JR receivers and batteries with Hitec servos, but I'm going to build an Impact and would like to use JR servos on it, the 8611s are the best servos available but for the elevators is kind of overkill power, is there anything that I can use there?, besides the 8611s I also got a pair of DS3421SA that I was trying to use on my Funtana 90 elevators, but on the first rigging pull ( not even overthrow, just 100%) I stripped the nylon gears, I don't know why on a 60+ torque servo, but after reading it looks like it's the choice for Jets, so I'm a little concerned on what to get.
Thanks for your time and help.
flyboy91 01-24-2006 08:41 AM
RE: JR servos for pattern
For servos on my own planes I run:
3421SA's on the elevator (2)
9411SA's on the wing
8611A on the rudder
I have not had a problem with the 3421's stripping out on me. I dont know if its because we only use 15 degrees max throw but these servos have worked out great for myself.
Andrew
apereira 01-25-2006 10:02 PM
thanks!!
