Balance
Just a question for you more experienced 3D fliers.
How critical is getting the right balance (COG)? Is this something worth tweaking? |
RE: Balance
getting it at the recommended is very critical.... after that and you are very comfortable with the plane you can move it in slight increments fore and/or aft until you find a position that you like best..
RE: Balance
Lee is right on, get it to reccomended CG then you can play with it to get to your comfort level
a couple of things to remember-- 1. nose heavy= fast landings 2. tail heavy= harder to control elevator,is real pitchy, hard to land. good luck;) |
| All times are GMT -8. The time now is 09:55 PM. |
