RCU Forums
-   3D Flying! (https://www.rcuniverse.com/forum/3d-flying-82/)
-   -   need some torque roll help (https://www.rcuniverse.com/forum/3d-flying-82/3897378-need-some-torque-roll-help.html)
tiktock 02-11-2006 01:30 PM
i need some torque roll help. i can TR the extra in AFPD all day, i can TR my shockflyer quite easily but, i cant seem to TR the nitro planes at all.[:@]
I'm flying the OMP 46 size edge and Mojo with a saito 91. they both fly extremely well but, i just cant seem to TR them.
any idea on what to do
thanks
CGAV8R 02-11-2006 03:09 PM
RE: need some torque roll help
I find both of those planes you listed pretty easy to hover/torque roll. Can you hover them? Is it just that the plane is not rotating? Anyway... Check your CG. I like to have mine towards the rear. Make sure you have 45* of throw on all surfaces. The plane will rotate in a torque roll quicker if you have a longer less pitch prop than it does with a shorter higher pitch prop. (12x6 rotates the plane slower than a 14X4) And most important of all....practice,practice, practice.
Hope this helps, now go practice:D
http://media.putfile.com/Two-Bros-with-Mojos-hoverfest
Aaron D.
McFlyboy 02-11-2006 03:25 PM
http://www.teamflyingcirkus.com/videos/TR-3DU.wmv
STG 02-11-2006 03:40 PM
ORIGINAL: tiktock
thanks
In AFPD Add weight to the fuse of plane (10 to 25 pounds on a 40%er) and crank up the sim speed on AFPD (120-170%). You can make it very difficult to TR on AFPD if you want. Also start with a plane that is a bit more of a handful to TR on the sim--some are very easy. I have found by increasing the difficulty when practicing on the SIM it has helped me develop my skills faster.
