2006 E-Fest Model?
Hi Andrew,
I would like to know some info about the plane you used (and the setup too). It seems it can fly F3A maneuvers quite well. It was a pity that you weren't able to finish your flight. I think you could have won without doubts. Well, you'll have best results on the E-TOC for sure ;) Thanks |
RE: 2006 E-Fest Model?
Juan,
The model I flew was designed by Larry Markey with some input from myself. The airplane is probably the most accurate foamy I have flown to date. I really love the way it flys. This airplane was setup with 3 eflight s75's for the aileron, elevator, and rudder. A hacker a20-34s. It used a VP unit that larry also designed. I had a 3 cell 480 thunder power pack and could fly for 5 minutes. The all up weight was 7.5 oz. We also have a pattern foamy that has a little longer nose and flys at about 6.2 oz ready to fly. I will get some pics of that up soon. In the short future I do believe Jason at insane foamies will be kitting this airplane. Andrew |
thank you very much Andrew,
I look forward to that plane being produced (or at least, his plans released) because I got shocked when I saw it flying (and I've seen many many foamies...) :) |
Animal,
Any more word on the Animaniac coming out soon? |
| All times are GMT -8. The time now is 05:01 PM. |
