RCU Forums
-   3D Flying! (https://www.rcuniverse.com/forum/3d-flying-82/)
-   -   help setting up FuntanaS 90 elevator (https://www.rcuniverse.com/forum/3d-flying-82/3996840-help-setting-up-funtanas-90-elevator.html)
dondee 03-05-2006 11:04 PM
i need help setting up servo horn for elevator on FuntanaS 90, if i used "Y" cable i have to counter faced the servo horn (between left elevator and right elevator servo) but the lingkage travel and deflection has different measurement for the left and right elevator. I also tried program mixing on my JR 8310 using elevator -> Aux3 mixing but i cant trim elevator function from the digital trim next to the stick, i had to trim the elevator and AUX3 separetly (which is pain in the &%$*)
Please help me if anyone have other solution for this horn and linkage setting... I can reprogram the servo (if i used digital Hitec servos) but it will cost alot just for 2 elevator servos...
i tried to move the servo mounting so i can use "Y" cable without worrying about the linkage travel and deflection but the fuselage will look wierd...
thanks for any solution....
Walt and Sage 03-06-2006 09:40 AM
RE: help setting up FuntanaS 90 elevator
It sounds to me like you are in need of a:
"reversing Y harness"
These are made for 2 elevator servos reversing
one servo so they both travel in the same direction
on the plane...
dondee 03-07-2006 11:15 PM
thanks a lot, i managed to get one
