RCU Forums
-   3D Flying! (https://www.rcuniverse.com/forum/3d-flying-82/)
-   -   What is 3d?? (https://www.rcuniverse.com/forum/3d-flying-82/403531-what-3d.html)
Norm from oz 12-07-2002 02:09 AM
What is 3d??
Hi guys,
I have come across the term 3d several times in r/c magazines, but no explanation on what type of flying it is?
Can someone describe what 3d is all about??
norm
rcflyer86 12-07-2002 02:35 AM
What is 3d??
3D flying can be described as a style of flying which can not be performed with the engine turned off. Lots of high alpha (high angle of attack) flying. Hovering (hanging the plane on the prop) and torque rolling are major parts of 3D. Waterfalls (flips) and elevators (plane falls strait down with the nose pointed strait foreword or slightly up) are also 3D maneuvers.
rcflyer86 12-07-2002 02:36 AM
What is 3d??
1 Attachment(s)
Touching the tail in a hover...
rcflyer86 12-07-2002 02:37 AM
What is 3d??
1 Attachment(s)
Hovereing low...
rcflyer86 12-07-2002 02:38 AM
What is 3d??
1 Attachment(s)
Torque roll...
rcflyer86 12-07-2002 02:39 AM
What is 3d??
1 Attachment(s)
This is a harrier. A harrier is flying strait and level, only really slow, therefore the nose is extremely high (high alpha)
Norm from oz 12-07-2002 02:45 AM
What is 3d??
thanks rcflyer86
that looks like one big challenge!!
Next question -- does it take a special plane to do 3d??
and what are the differences to other aerobatic planes like a pattern plane for example??
norm
rcflyer86 12-07-2002 03:12 AM
Planes
Well, to do 3D, it is best to have a profile plane or a 29% or bigger scale aerobatic plane like an edge, extra, cap etc... A good profile plane is a Morris Hobbies Sledge-540. I have a laner pro-twister, which is awesome. About the pattern plane. A pattern plane is designed for extremely smooth aerobatics, that is why they have such a long tail moment. A pattern plane is not a 3D plane. Other aerobatic planes such as a 40 or 60 size would not be good 3D planes. for some reason the small planes do not 3D as good as the big ones. The bigger that plane, the more stable it is. All of the planes in the pictures above are 40% scale. The have about a 10 foot wingspan.
rcflyer86 12-07-2002 03:13 AM
What is 3d??
1 Attachment(s)
This is my profile plane, the pro-twister.
mecam 12-07-2002 03:46 AM
What is 3d??
Here's an ARF for $189.00 :spinnyeye
http://www.3dbatix.com/images/stuff/ucd5sm.jpg
rcflyer86 12-07-2002 03:49 AM
What is 3d??
I should add that I bought that pro-twister for $75 and the os 46 for another $75. Cheap cheap airplane, but it sure flys awesome.
Norm from oz 12-07-2002 11:12 AM
What is 3d??
Can someone tell me if this would be an OK 3d plane ??
I have a 3w 75 and need a plane to glue it to.
http://www.modeldesign.com.au/Extra330S.html
norm
cameron 12-07-2002 12:18 PM
What is 3d??
Yeah I've been checking out this plane too.
Very cheap for its size, in case you guys from the US dont know the exchange rates, that kit is about $250 US!!!!!!!!!!
Pity the servos for this size plane are so expensive.
Im not very experienced in big planes or 3D, but the control surfaces look big enough to me.
What size servos would you guys recomend for this plane?
SAL98 12-07-2002 12:50 PM
What is 3d??
Basically 3D flying is taking a fixed wing flying aircraft and performing aerobatic maneuvers at close to and even under the planes flying stall speed. The aircraft looks as if it will just fall out of the sky any moment , but for some strange reason it doesn't.
There are also 3d maneuvers that take the aircraft into some really violent changes in attitude and speed starting from a normal flying condition. ( Blenders, Parachutes and tumbles are a few). Helis on the other hand define 3d a little differently. There versions of 3d are maneuvers that allow the helis to virtually defy gravity itself while pirouetting and twisting in any direction .
coony2787 12-07-2002 02:23 PM
What is 3d??
well i throw my 02 cents in
3d= any manuver that is not an airplane's capable flight path.
in other words if it looks like an airplane isnt capable of doing it i would call it a 3d manuver. :D
Chad
rcflyer86 12-07-2002 06:03 PM
What is 3d??
norm
From what I can tell...that plane would be AWESOME! a general rule of thumb is 90" wingspan or higher is needed for good 3D, and with a 92" span that planes looks like it would be great. A 3W 75 would be an awesome engine for it too.
rcflyer86 12-07-2002 06:06 PM
What is 3d??
I great 3D plane is an Edge-540. a Carden 35% edge won the xfc, so you know its a good plane. I dont think you can get a Carden where you are though. here is the website just incase you want to take a look. www.carden-aircraft.com also look at aeroworks at www.aero-works.net and one more....aerotech www.aerotech-rcmodels.com They all make great kits.
jc4me2 12-09-2002 11:16 PM
Would a AeroWorks Profile Extra be a good plane to
learn 3D on? If so, whats a good engine? I might be able to get a Saito 180 fairly cheap if I decide on it. Also, servos? I'm sure standard servos don't have enough torque. Thanks a lot, Jordan
wild3dfunfly 12-10-2002 01:35 AM
What is 3d??
35% and up will be the best 3D flyin planes:rolleyes
rcflyer86 12-10-2002 01:57 AM
What is 3d??
I agree, but a 29% AW edge is pretty good for a tighter budget
rcflyer86 12-10-2002 01:58 AM
Re: Would a AeroWorks Profile Extra be a good plane to
If I were you I would find an OS 1.60 FX, its a gret engine for that plane. www.ohiomodelplanes.com has an 80" wing profile edge, IMO that would be a better plane.
jc4me2 12-10-2002 02:40 AM
OK
It's cheaper and I like it better. Is the OS 1.60 best for the Edge too? Also do you think the split ailerons are worth the extra money for servos? Do you think it could fly on standard servos?
Jordan
rcflyer86 12-10-2002 03:26 AM
edge
I would put a Moki 2.10 on the edge. I would not put the split ailerons on it either. Just go with some high torque (110 oz. in.) servos and you should be just fine. I am sure the OS would be ok, but I saw one fly with the 2.10 on it and it was AWESOME. I think the kit is laser cut.....something that the AW is not. the AW plans for the AW really suck too, I would go with the OMP edge.
coony2787 12-10-2002 01:48 PM
What is 3d??
rcflyer why did you recomend such a big servo for the omp edge gs 540.
man dont go that route with the servo's i have already been there done that. the plane will come out way to heavy. and that 1.60 won't pull a 15 lb plane out of a hover very well. just remeber to stay as light as posible. if you put the flaps on your adding more wieght with 2 more servo's ,
by the way the instructions recomend mid grade servo's 60 to 70 inch puonds you have 2 on the elevator and 2 on hte rudder. the plane does not fly fast!!! :D
just my .o2 cents
Chad
jc4me2 12-10-2002 03:32 PM
Chad,
what engine did you stick on it? The Moki seems WAY out of the recommended engine size. Are you sure? Oh yeah, what servos did you use Chad? Thanks, Jordan
