RCU Forums
-   3D Flying! (https://www.rcuniverse.com/forum/3d-flying-82/)
-   -   Does the Edge like to pitch to the belly on vertical uplines? (https://www.rcuniverse.com/forum/3d-flying-82/404831-does-edge-like-pitch-belly-vertical-uplines.html)
mecam 12-08-2002 01:41 AM
3dbatixkid 12-08-2002 01:58 AM
I had a H9 Edge that would pitch to the belly in torkrolls, and it would also pitch very slightly to the belly in uplines. It might be that you built the plane with some stab incidence, and thats whats doing it. You might want to check it and re-do it if its not right. especially if you plan to use it for IMAC.
T_Hill 12-08-2002 02:09 AM
The Edge typically likes .5 to 1 degree of upthrust to fix this problem.
Tracy Hill
TerrellFlyer 12-08-2002 04:36 AM
my AW Edge doesn't pitch.
sfaust 12-08-2002 04:56 AM
Re: Does the Edge like to pitch to the belly on vertical uplines?
Which Edge? They will all be different based on the manufacturer and their designs. While they may all be Edge's, there can be significant differences.
Usually, a pitch to the belly on an upline could be from engine thrust, horizontal stab incidence, etc. These are easy to sort out with dynamic flight trimming.
The Edges I have flown did not show any significant pitching on the uplines (Aeroworks and Carden).
Diablo-RCU 12-08-2002 08:32 PM
A pitch to the belly in uplines can also be from too tailheavy. You should check the difference between uplines (power on) and downlines (power off). If it pitches to the belly in both, it's a weight balance issue (tailheavy).
mecam 12-09-2002 12:06 AM
Hmmm, you know I notice the pitch more after I moved the CG back 3/4". Maybe that is it. By the way the Edge is a H9 and planning to use it for IMAC Sportsman. I should move the CG forward for IMAC.
