Need help with the Typhoon 3d
Ok so I am about finished puting together my new Parkzone Typhoon 3d.. all I have left is putting the prop on. But, I can't figure out how to get the darn nose-cap off. Do I just pull it? I am pulling very hard and it isn't comming.. don't want to risk hurting something. Thanks.
RE: Need help with the Typhoon 3d
Yep, just pull it off. It gets a little stubborn at times. :D
...Mine was the same way.... If you have not flown it, land it with the power ON !!! It likes to take a dive at the groung with no power..;) |
your not the first person to have difficulty with spinner. on some typhoons its on there fairy snug. to pull off spinner just wiggle it side to side while pulling it. i posted this to another typhoon owner and it worked for him as well as on mine. once youve tryed different props a few times it will be easier to remove the spinner once its worked in a little. heres a video of mine with a 1320 lipo.. 2 ounces lighter so it floats even better and still has good punch with 13.5 prop http://media.putfile.com/Typhoon-4-9-2006 :D
| All times are GMT -8. The time now is 03:41 AM. |
