need help here?
wich electric rc plane is the cheapest and has 4 channels? and is power enough to hover in the air? I bought two pre-assembled planes a while ago, but the engine in them isn't more powerful than it barely lifts them off the ground. If I want a plane that can hover, wich planes would you guys recommend?
RE: need help here?
The two words you use "cheap" and "hover" don't work together. Here in the USA to get the hover will cost about $300 if you have the radio already. Dennis
RE: need help here?
You can get the Lightflite "Bug" on xmas special for $130.00 plus a battery(Lipo) and your receiver and this little wonder will do anything you can imagine - indoors or out. It " Floats"
RE: need help here?
hmm. is it so expensive? i just bought a Katana ep balsa-plane. it costs 1600NOK wich is just under 200$. it hovers quite well in the video on the site I bought it from. haven't tested it yet because weather conditions and stuff. it looks so fragile:/ - one hard landing and it will fall apart? http://rcnet.no/rc/video/katanaep.wmv . . . I've heard about the yak flight flex. this plane looks like it would survive almost everything:P. anyone tried this one?
RE: need help here?
The twist is usually about 79$ US, and the Tribute .36 is even less I think, either will hover nicely on th TT.46 with a 12- 4 prop, the twist a little better behaved I think.
| All times are GMT -8. The time now is 12:08 AM. |
