DA50 - Drilling Template?
I am building a GP Yak using a DA50, does anyone have a drill template for the DA50?
Mac |
RE: DA50 - Drilling Template?
I sure do
http://www.hiddenhangarrc.com/da/ The template and the newest manual are at the above link |
Thanks Bubba.
Mac |
Do you have the 100 and 150? My buddies could use them.
Mac |
Mac,
Sorry, Just the 50cc I remember seeing one in a manual some where. I'll start digging around and let you know if I can find the 100/150 templates |
It looks like the following link to QQ 102 Yak has a template. It's on page 49. Just print the manual out and there ya go.
http://www.somenzini.com/downloads/m...%20template%22 |
Bubba,
I drilled it out, thanks you saved me a bunch of time and aggrivation. Thanks again, Mac |
Mac,
No thanks needed, I'm glad I could help |
Mac
I have the same setup and the plane flies great, the engine is awesome. So much power!!!!!!!!!!! Carefull with the power! You might want to go pul pull for the rudder and she will balance perfect. Mike |
1 Attachment(s)
I have the GP Cap232 at just under 14lbs with the Da50 and vertical is truly out of site and in a hurry too boot [X(]:D
Evfast,
This is my first gasser, first pull pull. How about some pics of your setup, you know, were you put stuff. The throttle really has me confused and the choke? What do you use for a push rod? How and what do you use to mount the ign box???? Where did you route the fuel lines? I have the Imac Fromeco setup on the way.... what kind of connector is that DA ign power ??? I didn't order anything special from Fromeco.... Mac |
ORIGINAL: bubbagates I sure do http://www.hiddenhangarrc.com/da/ The template and the newest manual are at the above link Thanks man - I'm ready to bolt the motor onto my new H9 Cap 232 and your template will save time and hassle. Jerry O |
ORIGINAL: The MacDaddy Evfast, This is my first gasser, first pull pull. How about some pics of your setup, you know, were you put stuff. The throttle really has me confused and the choke? What do you use for a push rod? How and what do you use to mount the ign box???? Where did you route the fuel lines? I have the Imac Fromeco setup on the way.... what kind of connector is that DA ign power ??? I didn't order anything special from Fromeco.... Mac |
MikeEast,
No, I haven't gone any further w/ the project. I started the pull pull, and after I got one side done I noticed the cable was kinked, not sure if it was me or it was in there. Should I get new cable? So I still have all those questions and some more. Can you put the throttle servo right up close to the engine? or will it cause interference? Mac |
| All times are GMT -8. The time now is 01:39 AM. |
