RCU Forums
-   3D Flying! (https://www.rcuniverse.com/forum/3d-flying-82/)
-   -   Thrust needed for 3D (https://www.rcuniverse.com/forum/3d-flying-82/4929906-thrust-needed-3d.html)
ArmedZagi 10-29-2006 04:37 PM
My memory refuses to work today! I think I read somewhere that for 3D flight, the engines static thrust must be at least double the wieght of the plane. Say, I have a gas engine which produces 45lbs of thrust...the airplane cant weight any more than 22.5lbs if I want it 3D capable. Is this right?
Collin
rmh 10-29-2006 09:01 PM
RE: Thrust needed for 3D
Thatis what I like -but on that size plane -it is above average.
on my foamies I run 3 times as much on some
Maudib 10-30-2006 12:17 AM
It's somewhat a matter of preference and skill level.
Somewhere around 1.5:1 thrust to weight is the beginning of "3D capable" as 1:1 is capable of sustaining a hover with no pullout ability. 1.5:1 will pullout but slowly and without authority. Often at this ratio only the most experienced pilots have the comfort level to bring it down low as there's not much "extra power" to drag it out of a bad stick input.
2:1 PLUS seems to be the "prefered goal"
More is better in all situations, when tempered with wingloading... 30 oz per square inches seems to be the TOC average. But with all the superlight airframes coming out, 24-26 is realistic... So it's a trade between thrust and wingloading... and finding that happy medium will give you the best "experience" in your airframe.
Sometimes it is better to invest in CF wing/stab tubes/gear/tailwheel and lions than to buy a larger engine and become heavier nt he air. Other times it makes more sense to go the other way. It's an airframe to airframe decision process.
Otherwise if it was JUST about thrust... we'd all be putting 80cc engines on 50cc airframes...
ArmedZagi 10-30-2006 09:40 AM
Thanks, I'm building an airplane around an engine and was wondering where to aim for my all up weight. It's going to be a profile so it should come out pretty light. Sounds like as long as I build it under 25lbs it should fly great.
