Pump for Saito
Hello People!
which pump for Saito 82? - The Perry VP-20 Oscillating Pump - The Perry VP-30 Pressure Pump Thanks Sergio |
RE: Pump for Saito
Perhaps you should ask your question in the glow engine forum...
RE: Pump for Saito
VP20 - Oscillating is the one to use
The 30 will work but not as well and you need to put pressure taps etc in the crankcase to use it. |
RE: Pump for Saito
Why do you want a pump? The 82 has super quick response in the stock config. Is your tank more than a foot away?
RE: Pump for Saito
Thanks to everybody!
The pump because I want to put the tank on CG! Sergio |
RE: Pump for Saito
I have a 125 with the pump VP20 and a 100 without a pump.. Both tanks are mounted close to CG!! No problems with either motor.. The one with the pump is harder to prime when starting!!
LATER |
| All times are GMT -8. The time now is 05:24 PM. |
