RCU Forums
-   3D Flying! (https://www.rcuniverse.com/forum/3d-flying-82/)
-   -   Help Dp Ultimate CG? (https://www.rcuniverse.com/forum/3d-flying-82/533513-help-dp-ultimate-cg.html)
ckesinger 02-05-2003 01:40 AM
Where does this thing balance??. Right now it balances right on the leading edge on bottom wing. right side up. The instruction sheet really don't specify..or i just don't understand it.
X-Cellant 02-06-2003 12:43 AM
Ballance it about 3/4" in frunt of the rear upper wing center support. and work it back from there. Just pick it up under the wing at the center spar of the upper wing, when the horz. stab. is level it is going to be very close. If you need any other tips just let me no.
Ps I am flying mine about 3/8" in frunt and like it there.
Dave
krayzc-RCU 02-06-2003 02:48 PM
that plane has a very large range of cg i am 1/2 inch in front of the rear cabance mount. still dives a little on inverted flighti
ckesinger 02-07-2003 12:06 AM
It balances right on the leading edge of the wing, Will it fly there???
