Alternative engine mounting on GP Cap232
I have just bought a GP Cap 232 and am installing a Moki 1.8. I was wondering if there is a reason why I could not add an extra layer of ply to the firewall, and directly mount the engine to the firewall, with extended bolts going into the backing plate? I have seen this done on .60 size planes, and I can see it benefiting by dropping a few ounces of mount weight, but what might the cons be? Thank you, Mike.
RE: Alternative engine mounting on GP Cap232
Weight is the only issue there really... add wood and epoxy... shouldn't be too big of an issue though.
| All times are GMT -8. The time now is 11:51 AM. |
