OS 160 Drill size for prop??
I've got a OS 160 fx and a APC 18x6 prop. I need to know what size to drill the hole in the prop. Can somebody give me the drill size? Thanks
RE: OS 160 Drill size for prop??
hi S/D
Please DO NOT use a drill unless you really have to. I have a purpose made prop reamer. It's largest section is perfect for the OS160 shaft. Your LHS should stock them. regards piroflip |
A 1.60 has a 3/8" prop stud ( this kind of info is available all over the Net ) but you would be EXTREMELY lucky to drill it straight with a drill bit. As stated above you need something like this.
http://www2.towerhobbies.com/cgi-bin...&I=LXK248&P=ML |
I was too lazy I guess to search the net. A Prop Reamer it is. Thanks guys
