RCU Forums
-   3D Flying! (https://www.rcuniverse.com/forum/3d-flying-82/)
-   -   Hovering (https://www.rcuniverse.com/forum/3d-flying-82/611466-hovering.html)
Spadhawk 03-09-2003 02:13 PM
Hovering
Is it possible to hover a 4*40 with a GMS .47?
da king 03-09-2003 02:35 PM
Hovering
Sure but it will not be easy. Move the cg back a ton and get as much throw as you can and sure, why not.
Wingwiz 03-09-2003 04:10 PM
Hovering
1 Attachment(s)
:eek: Be careful with the CG on the 4star! 1/4 inch or less at a time:-) The 4Star has a higher aspect wing than most 40 size 3D aircraft, where you can get away with large CG changes. But sure U can hover the 4Star on a GMS.47 if not too heavy. (4.5-5.5lbs is good). When the motor is fully broken in try a APC 12.25X3.75W prop.
Like DA KING said " It will not be easy" Happy Flying all :D
