RCU Forums
-   3D Flying! (https://www.rcuniverse.com/forum/3d-flying-82/)
-   -   Feather Servo on Nitro Throttle (https://www.rcuniverse.com/forum/3d-flying-82/6164754-feather-servo-nitro-throttle.html)
K9 07-27-2007 06:29 PM
Hey guys,
Can I use a feather servo for a Nitro throttle servo? The servo is a Hitec feather servo w/ .15oz of torgue at 4.8v and the engine is a Evo .52. I have one and hooked it up and it works fine but I haven't tried it while running the engine yet. Thanks for your time.
k9
Cambo 07-27-2007 06:39 PM
RE: Feather Servo on Nitro Throttle
I usually like at least 25oz on my throttle. Hs 81 or the cs 12 are my favorite throttle servos.
WMB 07-27-2007 07:57 PM
I have had good luck with the HS55's. The barrel must be free to rotate of course.
kwboost 07-28-2007 02:34 PM
Ive had good success whith my antivibration mount method. Basically I use about 3 layers of doublesidded tape to attach servo to fuse and then use a zip tie to secure it. drill two holes on each side of servo and use zip tie like a strap. Before using this method I had servo failures due to vibration on feather servo. I also use straight ro to attach servo to throttle arm and locate the servo as close as possible to keep direct free linkage.
K9 07-28-2007 08:27 PM
Great info. Thanks everyone!
