RCU Forums
-   3D Flying! (https://www.rcuniverse.com/forum/3d-flying-82/)
-   -   dihedral (https://www.rcuniverse.com/forum/3d-flying-82/6853405-dihedral.html)
reg price 01-04-2008 03:05 PM
dihedral
i glued both halves of wings together,let set over night,noticed i have negative dihedral ,will this effect flying much?it is only about 3 or 4 degrees.
K.O. 01-04-2008 04:03 PM
RE: dihedral
It will make the plane more stable inverted and less stable right side up. The type of plane will have a lot to do with it. If your serious about how well the plane flies on the pitch axis it could be anoying.
K.O.
reg price 01-04-2008 04:08 PM
RE: dihedral
its a top gun xtreme,havn,t finished build yet,and weather,no rush.ccheap 3d plane good quality.
K.O. 01-04-2008 04:14 PM
RE: dihedral
I'm not familiar with the Top Gun Extreme. You may want to consider cutting the wing in half and reglue. It maybe a lot of work but most of the rework is at the wing root which is typically hidden by the fuselage anyway. If it were mine I'd probably reglue it.
K.O.
broke_n_bummin 01-04-2008 05:15 PM
RE: dihedral
If it's a 3D plane, there should be no dihedral and no wing incidence. The only way you'll get it to fly right is with flapperons. If you want it to fly right, cut it, straighten it it out and reglue it. It sounds like something might have gotten between the wing halves while you glued them together.
nitro wing 01-05-2008 01:44 AM
RE: dihedral
http://eastlancsmodels.co.uk/newstor...roducts_id=110
If this is the Plane,it should probably have no dihedral at all either way.I'd cut with saw carefully and epoxy glue it back.If there were joiners you will have to wrap the center in some cloth to regain strength.Perhaps fly it first,maybe with luck it wont be too bad.
reg price 01-05-2008 02:30 PM
RE: dihedral
i,ll try first,if its too unstable will attempt to saw in half,it will be a job & a half,maybe a jigsaw will do the trick.
nitro wing 01-05-2008 08:52 PM
RE: dihedral
The jig saw will do a hackjob,take it to a cabinetmaker or similar where they can make a clean square cut,with a fine tooth quality blade.Then the glue joint will be much better.
reg price 01-07-2008 10:26 AM
RE: dihedral
will fly 1st then maybe try cabinate maker
