G-trick
Just about to build a G-Trick, 91FX, Weston Throttle pipe. What sort of prop am I going to need. I want to keep the noise down but still be able to pull out of the hover??? do I need the Weton pipe?
g trick
im using a 15/8 apc,, works well,,,, but the g trick is a pattern type plane,, doubt very much on its ability to hover!
G-trick
i have the g-trick on a pipe with a ys-91 and it does the elevator and harrier well but not quite all the power need for t-rolling i am running 20/20 on a 15 x 8 so a 6 pitch could make the 3d a little better if push came to shove.....
www.krayzc.netfirms.com |
G-trick
thanks for the info. When I got it finished I will let you know how I get on.
| All times are GMT -8. The time now is 11:23 AM. |
