CG Problem in AW EDGE 60/90
whats up!!! first i know there is a big thread of this plane, but i dont wanna search all the tread, it could take me hours
I'm having some problems balancing the Aeroworks Edge 60/90!! The cg that i am using is 4 inches from the leading Edge. The plane is very sensitive to balance. if i put three 1/4ounces weights in the tail, the plane will go backwards, but if i touch the spinner then the plane will go forward... if i add more weights the pattern is the same. It never stay in an horizontal line (perfect balance) What do i need to do? more weights or not? i am using a ys91!!!! thanks a lot guys, Alex |
try putting tiny holes right in front of the wing tube on both sides of the fuse at 4" back from where the leading edge would be. Then run a thin piece of wire/string through the fuse with the wings on but not bolted tight to the fuse ....hang the plane...problem solved :D ...tiny holes will be covered when wings are attached !
thanks a lot. i try that!!!!
| All times are GMT -8. The time now is 09:03 AM. |
