Twist 3D 40 size set up advice
Hey everybody,
I have a Hanger 9 Twist 3D coming to me and I am looking for any advice I can get to get it set up for 3D flying. I have been flying planes for quite a while but just recently have gotten the itch to get crazy with 3D. I have a new O.S. .55AX for this plane and I ordered quite a assortment of props to test with. I have some Futaba Digital servos to use on the plane and a light weight batt. pack for it (3.3oz). Any suggestions you may have to help me set the plane up to be a 3D monster will be greatly appreciated!!! Thanks! |
RE: Twist 3D 40 size set up advice
No real need to try a buch of props,,,,APC 12.5 X 3.75 for a 46 up to 55, guarenteed. I've owned 2 of those twists.
ORIGINAL: Blade-breaker Hey everybody, I have a Hanger 9 Twist 3D coming to me and I am looking for any advice I can get to get it set up for 3D flying. I have been flying planes for quite a while but just recently have gotten the itch to get crazy with 3D. I have a new O.S. .55AX for this plane and I ordered quite a assortment of props to test with. I have some Futaba Digital servos to use on the plane and a light weight batt. pack for it (3.3oz). Any suggestions you may have to help me set the plane up to be a 3D monster will be greatly appreciated!!! Thanks! make sure you have all your travel adjusts at 100%....if the surfaces move to much use shorter arms...too little buy bigger ones....haveing an ATV of under 100% decreases servo resolution and accuracy. Use at least 15% nitro in your engine and keep it light as possible. |
Thanks for the tips. I will look into the lith batt. and regulator. I also will get some ball links.
ORIGINAL: djr1007 No real need to try a buch of props,,,,APC 12.5 X 3.75 for a 46 up to 55, guarenteed. I've owned 2 of those twists. |
ORIGINAL: Blade-breaker Hey everybody, I have a Hanger 9 Twist 3D coming to me and I am looking for any advice I can get to get it set up for 3D flying. I have been flying planes for quite a while but just recently have gotten the itch to get crazy with 3D. |
ORIGINAL: flygilmore ORIGINAL: Blade-breaker Hey everybody, I have a Hanger 9 Twist 3D coming to me and I am looking for any advice I can get to get it set up for 3D flying. I have been flying planes for quite a while but just recently have gotten the itch to get crazy with 3D. I wanted to follow up on your comment. At first I was a little upset. I did get the Twist and set it up the best I could for flying 3D, and I thought I was doing pretty good. I could hover it and do some harriers, it did have alot of wing rock and was not very stable in a hover, but I could do it and I thought that was normal . Even though I thought I was doing pretty good I wanted to see if the Mojo would do any better. I built a Mojo 40 size last week and flew it for the first time today. The components I took out of the twist and put into the Mojo so I knew that would be a fair comparison, I set up the radio ( expo ) the same as the Twist was set at. The Mojo ballanced out pretty good as built so I didnt change anything. On the first test flight I would have never thought I would feel so comfortable with this plane. Everything I was used to doing with the Twist was SOO much easier now, and NO wing rock!!! Second flight out I was hovering with no problem, harriers were super easy. Third flight out hovers right down to 12" of the deck. AWSOME! So I wanted to tell you that I did learn! But thinking back on it all I am happy I started with the Twist, because I do believe it helped my flying skills to fight with the Twist, and I would have never appreciated how good the Mojo is!! Looks like I have a Yellow dust collector!! I do appreciate your advice. Thanks. |
Yes :D another convert, There really is nothing like the Mojo. I must agree fighting the twist will teach you alot, Luckly you followed the advice even if only to prove the point.
another has seen the light:D
any 40-60 size 3d planes from horizon and seagul are junk. i'll take a ragged,battle tested mojo any day over the others. |
| All times are GMT -8. The time now is 06:17 PM. |
