RCU Forums
-   3D Flying! (https://www.rcuniverse.com/forum/3d-flying-82/)
-   -   will this engine fit? (https://www.rcuniverse.com/forum/3d-flying-82/8215690-will-engine-fit.html)
millertym2000 12-05-2008 02:01 PM
Hi guys, I'm thinking about getting this plane http://www.advantagehobby.com/produc...cat=175&page=1 It says it will hold the G20ei. I have a CRRC26cc. I've done some reserch and it looks like the CRRC is a little lighter then the G20ei. Im not sure about size though. Do you think it will fit?
Blade-breaker 12-05-2008 03:22 PM
RE: will this engine fit?
Anything will fit if you make the neccesary adjustments. But I think the gasser will be quite a bit too heavy for this plane. I would go with a Glow engine or chose a bigger plane for the gasser. A Saito or a OS two stroke would be my choice.
