Seagull Models Extra 300s
I just picked up a Seagull Extra 300s and I was wondering if it would hover with a Saito 1.25 with a 16 by 8 prop?Also what servos should I use? I have a hitec HS 5625mg witch I plan on using on the control surfaces(aileron,elevator and rudder) I also have an HS 5945 ultra torque.Will it be too aggressive for throttle?
RE: Seagull Models Extra 300s
use a 16x4w apc prop you want airflow not speed and a hitec hs 81 for you throttle.
I've also heard a 17x(4W or 6) do great on the 1.25. Oh, and if you get a Hobbico CS-12 for your throttle you'll get a .09second servo speed. That's pretty incredible speed. I do think that the 5945 is too aggressive. I mean, if you want to get rid of it....send it to me and I'll order a CS-12 for you. I'll even send you the MG version :D.
Hi Guys, I wonder the wing for seagull fit into the groupner? they both look same, My Groupner crashed just right after took off, the engine quit get hard landing and the left side damaged real bad.
Tom |
| All times are GMT -8. The time now is 09:04 PM. |
