Gyro Help!
1 Attachment(s)
Hey guys, im new to the world of 3d flight and seen and im currently searching for a great starter plane and noticed that some of them (used) came with a gyro installed......Please help me understand the purpose of the use of a gyro in 3d flight?
thanks~ |
RE: Gyro Help!
Stabalization, check this out, great gyro information. http://www.********.com/videoblog.htm
Ohh, Is that you hovering??? |
RE: Gyro Help!
The purpose is that someone thought it would make it easier. The fact is it is in no way needed to 3d and will more then likely cause more problems then any good it can do.
Honestly if I bought a 3D plane with a gyro, it would be removed prior to first flight. If a plane needs a gyro to 3d look for a diffrent plane. The purpose = to control one or more surface to keep plane pointed in a certain direction AE one on the rudder would operate the rudder, you could point the nose up flip the gyro on and it would move rudder direction needed to keep the nose pointed up. Add it to the ailerons and elevator and it would do the same and all you would be doing is controling the throttle. You don't need it to learn 3d and people don't use them, anybody that does is playing with gadgets and not really wanting to fly 3d.. BTW build yourself a MOJO 60 and put a Saito 100 in it , and have fun learning 3d;) |
RE: Gyro Help!
ORIGINAL: TimChurch The purpose is that someone thought it would make it easier. The fact is it is in no way needed to 3d and will more then likely cause more problems then any good it can do. Honestly if I bought a 3D plane with a gyro, it would be removed prior to first flight. If a plane needs a gyro to 3d look for a diffrent plane. The purpose = to control one or more surface to keep plane pointed in a certain direction AE one on the rudder would operate the rudder, you could point the nose up flip the gyro on and it would move rudder direction needed to keep the nose pointed up. Add it to the ailerons and elevator and it would do the same and all you would be doing is controling the throttle. You don't need it to learn 3d and people don't use them, anybody that does is playing with gadgets and not really wanting to fly 3d.. BTW build yourself a MOJO 60 and put a Saito 100 in it , and have fun learning 3d;) |
RE: Gyro Help!
ORIGINAL: bobs_201 Hey guys, im new to the world of 3d flight and seen and im currently searching for a great starter plane and noticed that some of them (used) came with a gyro installed......Please help me understand the purpose of the use of a gyro in 3d flight? thanks~ Never used or needed a gyro to fly 3D or torqueroll or hover and neither did anyone else I know that knows how to fly 3D. I guess if you take viagra you might also need a gyro... |
| All times are GMT -8. The time now is 09:12 AM. |
