new edge v3 omp problems
hy guys i bought the edge 540 47" v3 from OMP with a OS 81 FS
i flew it today but i dont like the way that the plane flews :S:S i dont know if i setup it wrong or waht happen because when i slow down de engine, the plane goes down very fast like if the nose was too heavy. Then i added weight in the tail, now the plane gets up and when i flew it inverted it gets up again, but when i slow down the engine it goes down like if the nose was heavy again... i dont know if the engine have a wrong angle because i make biger the hold of it. how can i know if is correct the angle of the engine Can anyone help me??? |
RE: new edge v3 omp problems
I have to ask, because you didn't say....
have you measured the CG?? WHere is it? |
i have one fo these, but i have an e set-up on it. i have great flight succes with it perfectly balanced on the recomended cg. one thing i have learned about this plane is this and have helped set-up several others, it like almost NO down thrust and a good bit of right thrust especially if your using an motor with lots of tourque!!! i will post of pics of mine soon!!
MIkey |
ocava, it sounds like you have some wierd thrust issues going on. Make sure the engine is not angled too much up or down. It should be straight with only 1 or 2 degrees right thrust.
exeter_acres
the CG first were at 11.5" then i addd weigt in the tail because i feel it too heavy at nose may be now the cg is at 13" BadBoy__MadMikey whts the thing did you lerned wiht that plane what is your set up ?? i hoop the engine is not too heavy beacuse is great have tons of torque i use 16x4 :D:D is a great engine KWJ48 how can i check the angle of the engine ??? i think that is the problem beacuse i make biger the hold of the engine but i dont know if is correct |
No way. 11.5" then 13". Suggested CG is 4.5" to 5"
jajajajajaa yeah sorry sorry the first cg was 4.5" now may be is 5.5" i was thinking in centimeters LOL sorry
| All times are GMT -8. The time now is 03:55 AM. |
