RCU Forums
-   3D Flying! (https://www.rcuniverse.com/forum/3d-flying-82/)
-   -   Diamant (https://www.rcuniverse.com/forum/3d-flying-82/84167-diamant.html)
JYM 03-22-2002 12:42 PM
Diamant
Hi !
It's a very good 3D plane. I got 2 of them... but not as ARF. It's the same model I own but 10 cm of wing span longer. I have to tell you that there is a weakness on the stab. The support of the stab on the fuse is too small to resist after big snap. The 1rst one was crached and repaired with modification. I put a bigger engine on it to support the overloading of the reparation. FX46 to FX61. The other one was modified and lighten. It is equiped with a FS52 and fly great.
For my discharged, I tell you that this is not a bad model and a easy solution can answer to that weakness.
Otherwise LASER MODEL (from my country, Belgium) makes very good 3D (Laser cut). One WE to built it ! (min FX61. A bit heavy... over 2,2 kg)
TOP MODEL from Czechia makes the world best 3D... the Diablotin Super. Very light model around 1,7 kg. Have a look on http://www.jr-models.cz/. you will be amased ! I got either a Diablotin XL 2m wing span and a moki 35cc. I saw in Nürenberg (world biggest Toy Fair) a new version of 2,6 m for 62cc !!!
There is also the Diabolic from Topmodel france. www.topmodel.fr
with a stab turning 180° which allow you new pattern figures.
I thank me for the time I spend answering you because most of time poeple forget beeing polite. Do consider either that I am not writting in my own language witch is French.
Any answers or questions are welcome,
Sheers from Belgium,
Yours,
Jym.
