RCU Forums
-   3D Flying! (https://www.rcuniverse.com/forum/3d-flying-82/)
-   -   MoJo .25 build questions (https://www.rcuniverse.com/forum/3d-flying-82/8561257-mojo-25-build-questions.html)
Max_Power 03-09-2009 08:47 PM
I've read and reread the manual, But I seem to have more tri-stock than instructions call for. Are the mating sides to each control surface to get triangle stock? The book mentions tri-stock on the v-stab and rudder. Am I to use the rest on wing TE/aileron LE?...Elevator LE and h-stab trailing edge? And then the slightly larger piece to align the h-stab to the fuselage? I'm assuming this is right...just couldnt find mentioned anywhere to put triangle on wings ailerons, or elevator. I'm also not quite clear as how to mount my battery/rx in the wing through the covering or how I axcess it ..this is my first glow profile...you don't have a photo do you? I can't wait to fly this thing!! Thanks in advance for your help. Todd
estone 03-09-2009 11:21 PM
RE: MoJo .25 build questions
yep put the tri stock on the mating sides of all controll surfaces, and to align the h-stab to the fuse.as far as the battery theres a few pics here http://www.swanyshouse.com/mojo25/construction.aspx
