RCU Forums
-   3D Flying! (https://www.rcuniverse.com/forum/3d-flying-82/)
-   -   Cermark Extra 260 70 (https://www.rcuniverse.com/forum/3d-flying-82/8968284-cermark-extra-260-70-a.html)
trpastor 07-27-2009 03:21 PM
Hey Guys,
I was thinking about getting this plane with either the spe 26cc, or the 28cc MLD. They say 8.8, to 10lb. If it hits 10, the cubic wingloading is only 9.1. seems pretty good. Definitly capable of 3d.
Can't beat the price either. Link here...
http://www.cermark.net/Show.php?TID=109&PSN=1813
Would you say go for it? Stay away? Other suggestions?
Thanks for your help
BarracudaHockey 07-27-2009 04:29 PM
RE: Cermark Extra 260 70
That motor pulled the 70" Yak around just fine with power to hover. Pull out was ok, not dramatic but not flat either.
Penuts 08-03-2009 09:08 AM
That is one of the best flying planes i have you wont go wrong with it,there isn't anything that plane cant do,go for it.
Just do the normal triangle stock around the fire wall and motor mount area, and if your building skill will allow you,put twin servos
for the elevator there is a spot for it.As for the engine i have a spe 26cc in mine,however i put a big bore carb on it and now im turning
8300 with a 16/8 apc. i think the spe 28 just might be a better choice or if you really want something awsome get the new SYSSA 30cc thats comming out soon.I hope to get one myself.http://www.syssaaircraft.com/index.html
All in All that is a great plane,
Good Luck
Uncas 08-03-2009 08:31 PM
ORIGINAL: trpastor
Hey Guys,
When you say cubic wing loading I suppose you are refering to what some call Wing Volume Loading (WVL), which I understand a good number is in the 7's. I don't care for this number on smaller planes but the Wing Loading at 10 lbs comes to about 23.7 oz/sq ft which is pretty good for a "heavy" build. At 8.8 lbs things get better and WVL gets into the 8's and WL = 20.9.
If you went glo - what size engine would you use? 2 stroke 1.20? A .90 seems to small for 8.8 lbs.
The plane looks like it flys great on the video. Gotta love the landing
