spinners
Hey,
I just got myself a Dave Brown 2 3/4 inch aluminium spinner. The problem is that the precut holes for the prop are too small, as I'll be using a 16x11 prop. Any ideas on how to inlarge them, cause I don't want to wreck this spinner. Thanks, Robert. |
Spinner slot size
Contact Dave Brown products. They should be able to supply you with a custom cut out for your prop at a nominal charge. Bill
Dremmel Tool
Use a Dremmel Tool its done all the time. Have done it for years
TN |
spinners
Finnished now, I used a hack saw blade to get the rough shape, then the rotary burr in the Dremel to smoothen it out. Took 10 mins.
| All times are GMT -8. The time now is 05:48 AM. |
