magic hand yak moki 2.10
i got the plane used and cheap and i also picked up a used but very new moki 2.1. i know it will be way over powered but all that use this engine what prop? i have a carbon majielc (sp) 20x8 and picked up some xoar 20x8 props is this a good 3d prop or should hvae got the 20x10. the plane is around 11 lbs
RE: magic hand yak moki 2.10
As suggested by my other post. That motor only needs 0-5% nitro. It can take a bit of time to break this motor in to achieve best performance. It can likely put out 20 pounds of thrust or better, making it an animal for your plane. props are a bit spendy but will give you a huge variance on your planes abilities. You do need to experiment with some good brand props.
