RCU Forums
-   3D Flying! (https://www.rcuniverse.com/forum/3d-flying-82/)
-   -   Need help picking servos for wings (https://www.rcuniverse.com/forum/3d-flying-82/9705759-need-help-picking-servos-wings.html)
Dirtyred2424 05-02-2010 08:48 PM
I just aquired a Funtana EP from my friend. One of the aileron servos has went out. Since I do not have the manual and can not find any information online about the servos for this model, Iwas hoping to get some advice from a more experienced hobbiest. I want to purchase two digital ones, please provide any help. The following is a link to the plane: http://www.raidentech.com/fuep3dbraerc.html
Safety Hawk 05-09-2010 12:58 AM
RE: Need help picking servos for wings
I'm not certain...but it looks like an HS-5065MG would work well.
Dirtyred2424 05-14-2010 10:12 PM
Thanks for the advice, I guess others do not know which ones will work.
JOHNS3D 05-14-2010 11:57 PM
from the wingspan of that airplane is small, so a HS65MG will work just fine on the wings, i use them on my 47" 3DSH extra.
Bozarth 05-15-2010 10:25 AM
ORIGINAL: Dirtyred2424
No - others know. There are hundreds of options out there, just do a little research. Most probably didn't want to do the research for your set-up.
Kurt
Dirtyred2424 05-17-2010 07:10 AM
OIunderstand, Iwas think that there was a basic servo for the type of flying style you are doing. So to start my research is there a certain place that Ishould look at or what variables should I take into account. Iwill also look at the HS65MG, but know I want to learn how to pick servos. Thanks for the advice guys.
JOHNS3D 05-17-2010 09:37 AM
dont overlook, just check different brand of airplanes and see the specs and recomended servos.....so you will learn a lot. On 42-47" wingspan airplanes most of the people use HS65, you can go cheap too but depends of what you really want.
