RCU Forums
-   3D Flying! (https://www.rcuniverse.com/forum/3d-flying-82/)
-   -   flames (https://www.rcuniverse.com/forum/3d-flying-82/970912-flames.html)
crzy4mot 07-18-2003 08:38 PM
flames
1 Attachment(s)
here is how i did it
crzy4mot 07-18-2003 08:40 PM
flames1
1 Attachment(s)
first cut the templet
lay them out on the wing and mark
crzy4mot 07-18-2003 08:43 PM
flames2
1 Attachment(s)
then apply with trim sealer(tricky part )
crzy4mot 07-18-2003 08:46 PM
flames3
1 Attachment(s)
all done know the other side
JohnVH 07-18-2003 10:26 PM
flames
Looks cool!!
I merged all your separate threads in to just this one. Next time hit post reply button instead of new thread button to keep them together.
Nice job!
crzy4mot 07-19-2003 12:49 AM
flames
hey thanks very much johnvh.. thanks for lookin out... i wasnt real clear on how that worked....
JohnVH 07-19-2003 12:51 AM
flames
Thats what were here for:thumbup:
BUCKETOBOLTS 07-20-2003 12:33 AM
flames
Great looking flame job. I'm a sucker for flames and checks...
Geistware 07-20-2003 11:19 AM
flames
Good job, are you a graphic artist by trade?
crzy4mot 07-21-2003 12:08 AM
flames
no auto tech if you can believe that. inspireing artist
i got the other side done know .... it looks sweet in the air.
shane.... the pics will be on later today..........
Geistware 07-21-2003 12:26 AM
flames
If you ever think about doing the graphics thing for others, let me know.
crzy4mot 07-21-2003 04:06 AM
flames
1 Attachment(s)
what would you need!!! i could do something for ya if you like them. all my flames are custom none are duplicated.here it is all done
crzy4mot 07-21-2003 04:10 AM
flames
i dicided on an ogange outside flame to keep orintation in the air.
rcFp 07-21-2003 09:22 PM
flames
very nice job
could you please explain the method you have used to apply the flames ?
( what is trim sealing ?
did you used windex over night ?
did you iron the edges to secure the flame to the white layer ?
thanks
3DFanatic 07-21-2003 09:33 PM
flames
That's neat. But where did you get the template??? I can't seem to find them.
crzy4mot 07-21-2003 09:44 PM
flames
well i found two ways to do it. both are pretty difficult
the trim sealer i use is made by monokote. its called trim sealer... your local hooby store will have. its tricky with larger parts of meterial.on the back it says to apply to both the piece your installing and the area it will go. i found that just wipping it on the area you wish to apply it and then lay it on top into position.it makes a bit of a mess.the color bleeds off the monkote onto your nice white film..... not to worry though it comes off when you wipe it with the same trim solvent.its nice because it doesnt deminish the shine of the monokote.....
the second is using vey low heat to apply.slowly work the area so that no bubbles form under the monokote.i found the 150 degrees F. works well.once the piece is in place raise to 175F then go over again.i then use 200f to stick the piece permantly into place.... its takes practice but man it looks sweet...let me know if theres anymore ??? the trick is over lap each peice over one another to make it seem they blend together. and 1/4 in seem doesnt show under the top layer. thank for all the great compliments guys...... hope this helps you all to have the trickest plane at your feild........
crzy4mot 07-21-2003 09:46 PM
flames
i hand drew my flames ive been drawing the msince i was a kid..... cut a templet then went for it......
crzy4mot 07-21-2003 09:48 PM
flames
i can cut you some custom ones... email me if your intrested....done or just templets!!!!
crzy4mot 07-21-2003 09:59 PM
flames
1 Attachment(s)
heres a straight down shot maybe you can print it out inlarge and cut some of your own........if you ever do.. post them for us to enjoy
Geistware 07-23-2003 12:37 AM
flames
You have PM
crzy4mot 07-23-2003 01:02 AM
flames
pm???????? dont know that term
crzy4mot 07-23-2003 01:05 AM
flames
unless you mean pre made... i c can cut them out and you can apply..i would also give you some detailed intsructions
bdphil 07-23-2003 01:49 AM
flames
crzy4mot,
You can never go wrong with flames. Looks great!
Ben
ptarp 07-23-2003 02:34 AM
flames
pm means "Personal Message". There is a button toward the bottom of every post labeled "pm" I am guessing he left you a personal message and is just letting you know to check it.
Regards,
Philip
3DFanatic 07-23-2003 10:44 PM
flames
Thanks, man! I just copied that image to my Hard Drive. I'll chop it up in Picture It and tile print it.
Then I'll have an excuse to build another plane. "I need a plane to put my flames on"
hehehehehe
