RCU Forums
-   3D Flying! (https://www.rcuniverse.com/forum/3d-flying-82/)
-   -   what are your best stunts? (https://www.rcuniverse.com/forum/3d-flying-82/986088-what-your-best-stunts.html)
easysport 07-24-2003 03:42 AM
I am just starting to learn 3D and need some instruction on how to do stunts. I can do spins and flat spins cuban and regular 8's, stall turns but am lookin for better and more. So come on and give me your best moves and please describe the stick movement to get them to work.
easysport 07-24-2003 03:45 AM
Oh by the way I am flying an H9 Ultra Stick
SunShyne 07-24-2003 03:54 AM
I can do a Cuban 8 to inverted and do some ultra violent snap rolls. Its an awesome sight to see!!
Im still a begiiner to learning IMAC and some 3D :)
JohnVH 07-24-2003 04:32 AM
Here, just watch the vid. Anything on it you want to know about?
Aerobatic Sukhoi
3dbatixkid 07-24-2003 04:41 AM
Check out www.3dbatix.com also for more video.
TallDude. 07-24-2003 04:47 AM
My best stunt? Landing.. in one piece.. everything else is just gravy, :)
3DFanatic 07-24-2003 05:41 AM
Try this with your Ultra stick...
Pass halfway down the field at about 3/4 throttle.
Pull straight up and wait for the plane to gain some altitude (if you're not high already)
THrottle back to idle and wait for the plane to stop climbing.
At the EXACT instant that it stops (no sooner no later), move the throttle to full, Rudder to full right, elevator to full down, and ailerons to full left (ie both sticks in and up).
If done properly, the plane should be at about 45° and doing some neat looking spinny-things around the prop.
It only does a few rotations, though, before it turns into a snap type thing.
3DFanatic 07-24-2003 05:42 AM
BTW...use high rates.
awood12345 07-24-2003 09:11 AM
I need some idea's of what I can learn for mu next stunt. any ideas? I want really complicated once and hard ones to learn. I like a challenge.
Alan
3DFanatic 07-24-2003 04:48 PM
I know a guy that can put his plane into an inverted flat spin. Set the transmitter down. Walk back t othe pits. Talk tot he other flyers for a while. Take a drink of coffee. Walk back down to the flight line. Pick up the transmitter and start flying again.
Try THAT :D
JohnVH 07-24-2003 04:55 PM
Probably the same guy that does it here, turn the TX off when its in the spin. Im not trying it, doesnt seem smart to me.
3DFanatic 07-24-2003 05:50 PM
Are you talking about Loyd? I can't remember his last name. The Flying Lawnmower that went to TOC guy?
JohnVH 07-24-2003 06:01 PM
yep
SunShyne 07-24-2003 06:18 PM
great..John shows up in this thread and now all of us newbies are gonna hide in the corner and shudder in fear.. ;)
southern_touch9 07-24-2003 06:53 PM
you want a challenging "stunt" harrier rolling circles are always hard. Rolling Loops I found to be kind of difficult. Try a snap rolling circle, snap and end up in KE flight, snap again, opposite KE flight, etc. all while going in a cirlce :) Im still working on this one:)
easysport 07-24-2003 07:27 PM
Good start and some good videos too but we newbies need directions not antecdotes so keep em coming with directions please
southern_touch9 07-24-2003 08:37 PM
I just got back from "the matchbox" aka a very very small field that I fly at when I dont feel like going to the flying club. The field has a huge china berry tree in the middle of it, with limbs hanging off at about 6 ft up. I just did what I am calling a hover limbo under the limb. It took a total of 3 attempts before I got it! My once white airplane now has green mulch all over it where I messed up a couple of times and had to go up into the tree. I know this sounds impossible but I will work on getting someone to go out there with me and get pictures. If your wondering why my plane is not in shambels for going into the limbs then wonder no more, I am flying my modified version of the SPAD Qhor .25. This thing is bullet proof! P.S. If you live in GA contact me if you want me to build you one of these things I build them for $35 bucks, I called them my modified qhor EZ hovers.
JohnVH 07-24-2003 08:46 PM
You need to ask what you want. Pick a manuever and ask how its done.
easysport 07-24-2003 09:03 PM
Well John most of the ones that I know the name of I can do except for Waterfall and Blender but I know there are many others that I dont know the name of can you describe these 2?
easysport 07-24-2003 09:11 PM
Plus John I would like to see this link turn into a primer for us newbies on 3D maneuvers so give us what you can
southern_touch9 07-24-2003 09:31 PM
easy sport what plane are you flying?
easysport 07-24-2003 09:33 PM
H9 ultra stick quad wing
southern_touch9 07-25-2003 12:16 AM
That is not the best airplane for Waterfalls or blenders. It should do a water fall with some hi-tech mixing and it should do blenders anyway but they probobly wont be done as good as say an edge540 would do them. Waterfalls can be done by going to roughly an 80 degree angle cut back on your power wait till the airplane is nearing a stall then full forward stick and full power (sometimes you have got to come back off the power then add it again on the bottom side of the water fall) and remember stay on that rudder.
Blenders look impressive but are easy. Climb to a very safe altitude kill the power, nose the airplane over give it full left alieron, let it roll about 2 times then suddenly add full right rudder and full down with the right aileron and it also helps to add some throttle. Remember all airplanes are a tad bit different (for instance I have to blender my laser3d totally different than I do my edge. These instructions are just a good place to start.
awood12345 07-25-2003 07:06 PM
southern_touch9,
I like some of those manouvers, I can rolling loop and rolling figure 8 etc. I don't have anything that could do harrier rolling circles so they will have to wait. The knife edge flick thing sounds cool, I can do them in a straight line but I have never tried them in a circuit. Are they 1/2 flicks from either side to side or are they 1 & 1/2 flicks.
Thanks for the suggestions, Please keep 'em coming!
Thanks again, Alan.
(P.S. I think I'll pass on the spin thing! :D)
3DFanatic 07-26-2003 05:48 AM
John - I didn't know Loyd turned his transmitter off... (Although how else would it stay in a flat-spin :D)
I agree, that does seem sort of dangerous and risky...
