HS 50 hightec servos mini SU-26
Im thinking about using HS50 hightec servos instead of HS55s in a Mini Su-26 Sukhoi 3dfomy.com model. With the HS50 servos the model should weight in at less than 6 ounces. Has anyone tried these servos on a small 3d foamy. These are the plane specs.
Wing span 35" length 28"
wing area 287 sq "
AUW 6.5-10
Great things 900 lipoly pack
Hacker a-20/34S or 50s (axi 2208/34 works as well) 4 hs 55 servos.
I'm going to use the Hacker motor, and a 700 lipoly pack
wing area 287 sq "
AUW 6.5-10
