hacker x-20 esc Q
will the hacker x 20 esc work with a thunder power 11.1 2100 pack?
thanks paul bingham |
RE: hacker x-20 esc Q
sure will...
You bet.
1 more question
will this setup fly the 3d foamy f-18 good? |
Oh yeah!! Have the same setup on the F15 and vertical is out of sight!
would there be any need for reinforcement needed?
paul |
you will need a round mount for the motor, then just put a couple pieces of scrap depron on each side of the mount to stabalize it and its good to go.
all right im getting the info i needed ....im fired up now
YEEEEEEEEEEEEEEEHAAAAAAAAAAAAAAAAA! paul |
can i go direct drive with the hacker on the 18?
Of course! Screw the engine on the back and hang on!!
how about this setup on a scale of 1-10
F-18 A20-20L w/ X-20 TP 11.1V 1320 pro-lite lipo's 9x6 prop HS-55 Servos (3) |
You will want a larger battery, say a 1600+ mah, but the rest is perfect for unlimited vertical! I run a 8x6E on my jets.
| All times are GMT -8. The time now is 08:41 PM. |
