RCU Forums
-   3DFoamy Support (https://www.rcuniverse.com/forum/3dfoamy-support-382/)
-   -   Pro-Cap (https://www.rcuniverse.com/forum/3dfoamy-support-382/3622867-pro-cap.html)
Funflyaddict 12-06-2005 01:31 AM
Pro-Cap
John,
Just like to say that the quality of the depron in this kit is fantastic, and the laser cutting is incredible, so clean!
Just a few questions though.
I cant find the pull/pull cables, are they in a separate bag?
Can i run a single HS-81 for ailerons?, would it be to hard to do that, or should i just go grab another servo from the LHS?
Thanks!
Owen
JohnVH 12-06-2005 01:36 AM
RE: Pro-Cap
Hi, we dont use pull pull on any planes anylonger, check out page 20 here, this should clear it up.
http://www.3dfoamy.com/Manuals/Edge540_Manual_PRO.pdf
Funflyaddict 12-06-2005 01:47 AM
RE: Pro-Cap
Ahh ok thanks, sorry i was just reading the manual for the cap, saying that parts list was Pull Pull wire, and instructing how to set it up.
Did i say its an awsome kit:D
Thanks for the quick reply!
Owen
Funflyaddict 12-18-2005 11:40 PM
RE: Pro-Cap
John, can i use White PVA glue instead of Epoxy on the spar?, and also on the ply motor mount sticks.
I ran out of epoxy and have so much white glue its not funny.
Going together well, i snuck it out before X-mas, and used the excuse "Can i build it now so its ready on Xmas day:D..
JohnVH 12-19-2005 11:19 AM
RE: Pro-Cap
Well, I have been CAing mine in and had no problems.
Funflyaddict 12-20-2005 08:48 PM
RE: Pro-Cap
John, yet another question:eek: ...
With putting the wing into the fuse, Once you'v laminated the wings on the Cap, at 12 mill thick they are to thick for the 9 mill gap in the fuse to get them through. I thought you could just widen the gap in the fuse..but then it would be lose at the front.
How do i go about this?
The edge manual you posted above tells me to do this:
38. Take a scrap of foam and slide it along the wing cutout to perfectly size it. When
satisfied, slide the wing into place. Center the wing and then push it forward into
the LE notch. Square the wing up to the fuselage by moving the TE tab into the
wing cutout.
TIP: When sliding the wing into place, use the edge of the table as a support for the
lower half of the fuselage.
But it still ends up being 3 mill to small..
Could you please explain to me how to do this?, sorry about this, but i dont want to screw my kit up[:o]
Owen
JohnVH 12-20-2005 09:53 PM
RE: Pro-Cap
It will go through, spread the fuse apart a little bit, slide the wing through at an angle instead of 90 degree's like it will be glued into place. Hope this helps.
Funflyaddict 12-20-2005 10:25 PM
RE: Pro-Cap
Ok thanks John, i got her through.
Thanks for your great support, and not getting itred of my questions (Wellthat appear through your posts:D), your planes and support is really the best
Thanks heaps
Owen
