Prop fit and Trim question
Is it typical to trim the back of the smaller props to clear the screws on the "Little Screamer" motor hub ? This is when mounting with the O' ring across the prop. Also as I am new to small 3D foamie's can anyone give some basic set up ideas to be able to perform 3D aerobatic's.
Thanks , in advance, Marcwv |
