RCU Forums
-   3DFoamy Support (https://www.rcuniverse.com/forum/3dfoamy-support-382/)
-   -   Inrunners? (https://www.rcuniverse.com/forum/3dfoamy-support-382/8929193-inrunners.html)
Spitfire222 07-13-2009 12:10 PM
Inrunners?
Hi everyone,
My first 3D foamy was an E-Flite Tribute using the Park 400 Inrunner motor with gearbox. I was wondering if the 3Dfoamy.com planes have a provision or can be modified for this size inrunner motor? I'm interested in getting one of these planes since I haven't had a 3D foamy in a long time, and I wanted to use all my micro equipment from the Tribute. If not, I'll just have to get an outrunner, which is actually not a big deal considering all my other equipment (ESC, Li-Po's, servos, receiver) should work.
Thanks in advance for your help!
JohnVH 07-13-2009 12:16 PM
RE: Inrunners?
Hi, they can be, I have not used one, is that a stick mount? For the pro planes I use HS55 or similar size/power servo's.
Spitfire222 07-13-2009 12:29 PM
RE: Inrunners?
Hi John,
Yes, the gearbox is a stick-type mount, though it can be firewall mounted from the front. The gearbox has screw holes to be mounted behind a firewall, not in front like most outrunners. I have HS-56's that I have loved since getting them!
I should probably get an outrunner anyway, since that seems to be the norm these days. Most 3d type foamies I see are designed for them.
JohnVH 07-13-2009 12:45 PM
RE: Inrunners?
Ok, well, your in luck, my pro models do have a stick in them that they can be mounted onto. For an outrunner you would cut that stick off and put a disc in the nose.
