RE: Cellpro 4s Balancing Charger
Hi Greg and Fred,
A few questions about the soon-to-be-released 4-cell charger:
What is the maximum output wattage?
Does it discharge or cycle at all?
Can you explain what it means that the charger can be "directly tied" to the West Mountain discharger? What does this do that using the West Mountain CBA with a different charger wouldn't do?
Is max charge time limited? Can I adjust the limit?
What about maximum mah's of charge? Is that limited? Can I set the limit?
Does the unit have a fan?
Does the unit have an On/off switch?
thanks!
-Eric
