RE: CT4S Front belt replacement
I took off the top deck and one of the large mounts that holds the front diff in place to replace mine. Engine mounts do not have to come out, all the work seems to be in taking the front suspension apart. Make sure you have enough tension on it, or it will come off the rear gear and jam itself in there pretty good.
