RE: Beginners FAQ?? We need your help!!!
What is a Power Panel? Advantages/dis-advantages. What do you need to make it work?
What can a Power Panel do? How do you determine where to set the plug power level and why?
Fuel pumps - manual or electric? Advantages/dis-advantages of each type. Mention that some electric pumps don't have switches because they are meant for the Power Panel to control.
2 blade vs 3 blade prop debate. APC vs MAS debate. Pusher props?
Spinners vs prop nuts only(various types) Advantages/dis-advantages of each.
Since it is common, what is the flywheel on Evolution engines and can it be removed?
Different types of clevis's, EZ Links, Quick Links and other such hardware.
What is a Z-bend and an L-bend? What type of links required to make them work.
How do you keep a nose steering tiller from slipping?
Foam vs rubber tires. Advantages/dis-advantages of each.
Why is my new ARF covering all wrinkled and how can I fix it?
When/where should I use Loc-Tite?
What is a CA hinge? ......Robart Hinge pin? .......pinned flat plastic hinge? How does each type get installed? Advantages/dis-advantages?
