Old 03-19-2006, 07:41 PM
red head
Default RE: solartex not sticking
Did you take the backing off the piece you are working with ????
I haven't worked with Solartex in years but this might be worth a try and it shouldn't hurt if it doesn't work. Use the windex method !!
Spray windex on the area then put the trim down and squeegie most of the moisture out from under the trim then just let it dry a couple days. If it holds ok go back over the edges with clear finger nail polish. GOOD LUCK. ENJOY !!! RED
