4-stroke on US 60
Hi gang, quick question. I am building an RCM Ultra Sport 60 from plans and am going to use a Magnum 91 4-stroke. The problem is the control linkage to the carburetor. I am using a GP engine mount. The way the engine bulkhead around the engine is constructed the engine mount touches the inside of the balsa bulkhead top and bottom (as in top in bottom of the plane-side mounted engine). Does anyone have a suggestion how to mount the throttle linkage? I am almost done with the plane and would like to do this right. Has anyone done this before? I had considered using the Dubro 4-stroke linkage modification but there is no room to attach the pivot on the side of the engine mount. Any ideas? Thanks!
Travis
