ORIGINAL: RCKen
1.25 ton,
Instead of hooking up a 3rd line to fill the tank with, try this. Hook the fuel line on the inlet of the carb. then use a piece of brass tubing to "splice" it together with the line going into the tank. When it's time to fill the tank just separate the fill line where it's connected with the brass tubing.
Ken
Ken are you saying to fill the tank THROUGH the remote needle valve? You seem to be addressing a non-remote needle installation.
