RE: 29% Katana-S ARF---Aeroworks!!!
cstevec I had A H9 Cap went thru same thing ended up being the switch it would breakdown at higher rpm then after it would Idle down it was ok till I throttle up good luck. did your CG come out the same as the manual.Roger that
