RE: First Large Plug
Todd, 7.9" wide at the nose. The trailing edge of the cheek vents stick out a smidge more, about 8.25" wide at the cheek vents. Still wide, but this is over 2" more narrow than the fat pig I'm flying now. Pic looks pretty blocky in the nose, but I plan on sanding that out. The nose is basically an Excellence nose, but more narrow and a bit more sweep on the cheeks.
Do you cast your poly foam, or do you have a source for blocks? What densisty do you suggest?
