RCU Forums - View Single Post - Official HPI MT2 Thread
Old 03-30-2006 | 05:43 AM
  #5576
simienastro
Banned
Default RE: Official HPI MT2 Thread
If I was you and you would not want to continue to fork out mid range prices - which added up are more than the heavy duty parts; I would get the heavy duty final gear for the engine you have lol. From my understanding its more powerful than the 18ss, so I would definitly get them. You should NEVER over shim your gears as the added friction and lack of play will kill them. In saying that, you can create a different atmosphere for the diff in terms of lubricants to help ease the pressure. You can use various weights engine oil or motor bike oils with different viscosities. I have set mine up with a car diff oil and my MT2 diffs are 1/4th filled with this oil so that they are always lubricated. My shims are standard shims with 1 extra...thats it. Bearing in miond that these will not last forever but if you train your self to ease off the throttle so its NOT "WOT" all thime when turning corners, your diffs should last longer.
On pages roughly 200 and below there abouts there was a poster who did the same thing as I did by putting and experimenting with various lubricants and viscosities with his diffs, and he even put a quick refil hole in the top - which is very good if yu have the alum ones and you can fabricate a tapping for the cap; not too hard.
ORIGINAL: mkr
Thanks for the advice again [8D]
I'm pretty new in this nitro business..so sorry for all these questions.
The thing is that an engine like O.S. .18 aswell as all other things is quite expensive in Denmark, around 308 $ for O.S. .18, and I need to order it home, so I better be damn sure I can make it fit. Ordering things at towerhobbies just puts on a toll plus high UPS rates, and just makes it even more expensive.
Also I apologize my english, the hardened diffs I mentioned was in fact, HPI final gear set - they came with 3 washers I used, does'nt seem to need additional shimming, but I could be wrong. The differentials are not themsleves hardened as far as I know (stock mt2 ones). So will they be shredded to pieces? I mean, is the O.S. .18 too much still? I don't want to do wheelies and constantly replace ripped drivetrain gears if the engine is too powerful, I just want my truck to have a significant punch without destroying expensive parts all the time.
EDIT: just checked HPI's page.. apparently the diffs are hardened. Sorry for not checking this myself.
